Manual til toppakning skifte
Deprimera
Til DOHC eller OHC motor da?
Har en manual til sierra OHC hvis det hjelper?
Utdrag fra Haynes Manual Ford Sierra OHC
20 Cylinder head - removal and
refitting (engine in vehicle)
Note: Refer to the warning in Section 8 and
the note at the beginning of Section 21 before
proceeding.
((8 Method of engine removal
Warning: Vehicles equipped
with air conditioning:
Components of the air
conditioning system may
obstruct work being undertaken on the
engine, and it is not always possible to
unbolt and move them aside sufficiently,
within the limits of their flexible
connecting pipes. In such a case, the
system should be discharged by a Ford
dealer or air conditioning specialist. The
refrigerant is harmless under normal
conditions, but in the presence of a naked
flame (or a lighted cigarette) it forms a
highly toxic gas. Liquid refrigerant spilled
on the skin will cause frostbite. If
refrigerant enters the eyes, rinse them
with a diluted solution of boric acid and
seek medical advice immediately.))
Removal
1 Disconnect the battery negative lead.
2 Drain the cooling system.
3 Disconnect the coolant hose from the
thermostat housing.
4 Disconnect the wiring from the temperature
gauge sender.
5 Disconnect the HT leads from the spark
plugs and from the clips on the camshaft
cover and remove the spark plugs.
6 On carburettor models, remove the air
cleaner.
7 The cylinder head can be removed either
with or without the manifolds. If desired, the
inlet manifold can be unbolted and moved to
one side, leaving the wires, hoses, pipes and
cables connected, but care must be taken not
to strain any of the wires, hoses, pipes or
cables.
8 Unscrew the three securing nuts and
disconnect the exhaust downpipe from the
manifold flange. Recover the gasket.
9 Disconnect the coolant hose from the clip
on the exhaust manifold hot air shroud, and if
desired, remove the exhaust manifold.
10 If the inlet manifold is to be removed with
the cylinder head, disconnect all relevant
wires, hoses, pipes and cables, otherwise,
unbolt the manifold and move it to one side,
ensuring that it is adequately supported.
11 If not already done, unclip any wires and
hoses from the camshaft cover, noting their
locations for use when refitting, and on fuel
injection models unbolt the bracing strut
securing the inlet manifold to the right-hand
side of the cylinder head.
12 If desired, remove the thermostat and
housing, and the temperature gauge sender.
13 Proceed as described in Section 21 for
cylinder head removal.
Refitting
14 With the cylinder head refitted as
described in Section 21, proceed as follows.
15 Where applicable, refit the temperature
gauge sender and the thermostat and
housing.
16 Refit the manifolds and/or reconnect all
wires, hoses, pipes and cables, as applicable.
17 Reconnect the exhaust downpipe to the
manifold, using a new gasket.
18 Refit the coolant hose to the clip on the
exhaust manifold hot air shroud.
19 Refit the spark plugs and reconnect the
HT leads.
20 Reconnect the temperature gauge sender
wiring.
21 Reconnect the coolant hoses to the
thermostat housing.
22 Fill the cooling system.
23 If not already done, refit any hoses and
wires to the camshaft cover, as noted during
removal, and on fuel injection models refit the
inlet manifold bracing strut. If splined type
cylinder head bolts have been used, leave
these operations until the bolts have been
finally tightened after running the engine.
24 Refit the air cleaner on carburettor
models.
25 Reconnect the battery negative lead.
26 If splined type cylinder head bolts have
been used, start the engine and run it at 1000
rpm for 15 minutes, then stop the engine,
remove the air cleaner and the camshaft cover
as described previously, and finally tighten the
cylinder head bolts to the fourth stage (see
Specifications). Refit the camshaft cover on
completion, then refit any hoses and wires,
and on fuel injection models the inlet manifold
bracing strut. Refit the air cleaner.
