En syyk bil er død!
momo
  • Svar 34
Tragisk at kjører så lavt på turtall på den bilen. Litt komisk som det blir nevnt tidligere i tråden. Men er det noen her som har kommet over specs på motoren/bilen? :)
[V]2012 Skoda Octavia RS+, Race Blue Metalic
[x]2008 Toyota Auris 2,0 D4D TTE Edition, Night Sky Black
[x]1998 Nissan Skyline R34 GT-T, Sølv perle
[x]1993 Honda Civic HB Vti, Milano Rød
Har du ikke lest tråden?
Står litt info om motoren lenger opp da....
O-1999 VW Passat 4Motion.
O-1989 E34 535. prosjekt.
Får ta det en gang til da så alle får det med seg :)
"This car, a '02 Nissan 350Z owned by Option magazine, Japan's leading automotive tuning lit, was made strictly for that race and to eventually break the event's average-speed record of 207.78 mph, printed as the fastest road race average speed by Guinness Records"
Bilen har litt over 750hk.
motor specs:
Almost every part inside and outside the engine is a JUN fabrication. JUN cams, boasting a 272 duration and 9.8 lift, help the stock valves open wide enough to let the exhaust and air move efficiently during the high speeds, which is also assisted by the JUN valve springs, while the air makes its way to the JUN cylinder head via a GReddy air intake, a VH45 throttle body, and a custom JUN intake manifold.
Inside the V-6 block, tunneled to make approximately 3.8Ls, are six JUN pistons crowned with matching piston rings. These powerful slugs help the fuel, which is spit out by 740cc JUN injectors, detonate effectively. The leftovers are thrown out by a JUN titanium exhaust system by way of JUN headers. The most important part of the mechanism was clearly left to GReddy with the T88H, as as its blow-off valve, Type C wastegate, and E01 boost controller"
- 85 Toyota Levin AE86 - F20C
- 87 Toyota Supra MK3 - 1JZ-GTE
Dette er et par år siden, så det har de gjort.
Det er bilen i andre post her som er den 'nye', er jo 1 år gammel den og nå.
Ser de ikke er like.
Ok. Men ut i fra det jeg har lest nå, så burde den bilen gå godt. JUN deler er jo kjent for å være noe av det bedre på markedet. Takk for infoen.
Hvis du følger med så svinger han mot venstre for å kontre sladden bilen får pga blåst bakhjul.. Uansett lite man kan gjøre når man får sladd i 200kmt+
Er det det man kaller power drifting? Vært moro å fått kontrolert den sladden i 200km/t++
