LFS S2 tråden
  • Svar 2.1k
S2 Alpha Patch Q
Hello Racers!
First... THANK YOU to all those who contributed (content and testing) to the recent series of Test Patches, as we worked through the new language support system and all the complications it involved. It's now easy to type correctly into LFS, in many more languages, including Russian, Greek and Japanese Katakana!
There are five new translations as well, and several improvements and fixes. All the changes since Patch P2 are all listed below.
New language support :
Several updates allowing new translations and new character sets...
6 new codepages in addition to Latin-1 :
- Cyrillic, Greek, Central Europe, Turkish, Baltic, Japanese (Katakana)
5 new translations :
Russian, Estonian, Serbian, Greek, Polish
Automatic codepage selection, when changing keyboard in Windows
New text entry system, handles multiple codepages and colours
User can select code page manually, if required (press CTRL)
Text colours - CTRL + 0 to 7 : change colour / CTRL + 8 : default
Can use a comma instead of a full stop when entering a number
New ^9 code - restore original colour without changing codepage
Autocross editor distance measure display is now translatable
CTRL in text input box : click down arrow to show characters
Other updates :
Pit stop required (yes or OK=done) is now shown in the F12 menu
Avoiding invalid key beep on Scroll Lock, Num Lock and Pause
Faster text draw by using fewer, bigger textures (less swapping)
SHIFT+O now enters options from setup screen (same as in game)
Join screen shows selected player and gives access to options
"Corrupted NameReply" error message removed from List of Games
New /out command - ignored by LFS but seen by InSim programs
Controller buttons can be assigned to text keys CTRL+F9-F12
Fixes :
FIX : Wrong fuel amount transferred to new player when taking over car
FIX : Faulty online host sometimes causing LFS to hang in List of Games
FIX : Some missing characters added to Latin 1 code page
FIX : "Race Ends : 1" message shown wrongly in garage
FIX : KNW filenames depended on selected language
FIX : Some changes to the text in braking lessons
FIX : Numeric keypad 0,1,2,7,8,9,-,/ keys now work correctly in game
FIX : Loss of racing line rubber : "Path info changed" message
FIX : Text about upload of 56k modem - in fact 33.6 kbits/sec
FIX : Holding SHIFT+X from in-game put LFS into a strange state
FIX : Repeated message "Could not load colours - using default"
FIX : Crash if track changed when user was in select car screen
FIX : No mid-race join option now only active if 2 cars in race
FIX : Last key pressed in text box could activate its function
FIX : TAB and SHIFT+TAB should now show all cars and not crash
FIX : Page Up and Page Down keys generated " and ! characters
FIX : Small numerical error in foot-pounds and bar units
FIX : Third decimal place of message text size was not saved
FIX : Max length player name with a full stop would be corrupted
FIX : Various bugs and crashes when using nogfx / invisible host
FIX : Some problems with kick/ban and sharing of ambiguous names
Download : (Download to LFS folder, right click, "extract to here")
http://www.liveforspeed.net/file_lfs...HA_PATCH_Q.zip
Dedicated host : (For hosts only)
http://www.liveforspeed.net/file_lfs..._S2_DEDI_Q.zip
NOTE :
This is a compatible patch, that means it can connect to all versions of LFS back as far as 0.5P. There are no physics updates. We know that a lot of people are waiting for them, but we always keep physics updates, track and car changes, multiplayer changes, to a single patch, because each time we do that, the online community is divided and the hotlaps must all be deleted. That's why we don't release single physics updates here and there. The important physics updates are the next thing on the list!
Hope you enjoy the Patch Q updates!
Have fun!
Nissan 200SX RS13 med trivelige mods.
www.sandvik-bros.com
Noen som veit åssen prog jeg må ha for å få lagd lfs film? Har prøvd i vegas 5.0, og windows moviemaker, fungrerer ei...
Har jo ratt og pedaler nå, og 1140 hk i Xr Gt turbo`n, så d sladder greit bortover sletta, derfor hadde d vært morro å mekka en film.. :)
85` Sierra is Vinterbil
x87` Fiesta 1.1 pirat
X79` Kadett C 2.0 8v
viss du leser på linken der du lastet ned patchen..så står det nøye ka update du må ha..det fungerer nemlig ikke med den nyeste updaten trur jeg..der er en link der du kan laste ned den updaten du trenger på siden også.. happyhappy
Lasta ned update/patch,eller hva som ligger under selve mecanik prog, men fungerte ikke da heller.. Svarte... :deng
