Sigheri`s Toyota corolla KE35
sigheri
  • Svar 291
Jeg fant jeg fant.... her: http://www.billzilla.org/4agstock2.htm
INLET MANIFOLD - 20 Valve
Very good indeed - They have a single throttle butterfly for each cylinder, and so are about as good as a very good racing inlet system.
Hot property, they are!
One slight problem though, if you want to fit one to your 16v - They won't bolt on and so require an adaptor, and more importantly they have ZERO inlet manifold vacuum, so the computer won't work ... An aftermarket add-on only for the 16v's.
(That being said, I've read a few reports from various people that say that they've gotten the stock 16v computer & 20v inlet manifold to work together okay)
1968 Ford Mustang HT "Pro Touring" 352BB FE 500hk, C6, 9"DL, Viper red.
1998 Ford Mustang 3,8V6
1995 Chevrolet Astro EXT AWD
2001 Audi A6 V6 2,7BiTurbo quattro
Fant også dette....
størrelsene på dysene på de ulike 4AGE motorene.
TVIS big port 182cc/min
Small port 235cc/min
4AGZE 365cc/min
20v 295cc/min
Skal tro om man tjener noen hk på å bytte dyser fra en smallport til en big port.... :rolleyes:
Nåh! Du har jo vært effektiv siden i går!:pray Det ser bra ut det greiene du har funnet frem til!
Når det gjelder dekkene, var det 195/50/14 som stod på suprafelgene. (sjekka) Det er en ganske fin størrelse for ae86, starlet, og lignende. 185 er sikkert helt greit det og :)
_________________________
'69 Lincoln MKIII, '79 Ford Mustang, '94 Toyota Supra SZ, '94 Toyota Levin gt-apex 20v, '68 Gilbern Genie, 74 Datsun Cherry
