Justering av tomgangen
Ulti_Man
fant dette på miata.net:
Idle Speed Adjustment
Robert Meushaw rvmeush@home.com are the tips of several others who helped him.
As a matter of intellectual curiosity, I decided to investigate the correlatio shares some of his experiences when working on accurately setting his idle speed. Included n between the Miata tach reading and the IG- signal on the diagnostic connector. Fortunately I have a digital storage oscilloscope and a digital frequency measuring multimeter. The signal coming from the IG- test point is a pulse approximately 2 milliseconds in width and approx. 12 volts in amplitude. I measured the pulse frequency when the tach indicated that the car was idling between 700 and 1000 rpm. The scope reading and frequency meter reading indicated approximately 29 pulses/sec. Multiplying by 60 gave 1740 pulses/min., which is not correct. But, dividing by 2 gives 870 pulses/min which is about right. Therefore, the conversion from the IG- signal to rpm is
RPM = ( PPS x 60)/2 or PPS x 30
This is perhaps more effort than is needed to get a correct rpm reading, but inquiring minds want to know. Please note that these measurements were taken without shorting the TEN pin to ground, but the rpm signal correlation would still be the same.
The tacho connects to the IG terminal on the diagnostic connector.
The diagnostic connector is on the driver's side and is cunningly
disguised as a DIAGNOSTIC CONNECTOR :-) (close-up view)
It's nice when things identify themselves :-)
If you pop the lid of the diagnostic connector, you'll see a bunch of
terminals and, inside the lid, a little diagram saying what the
terminals are.
To set the idle, put a jumper wire between terminal TEN and ground, and
connect the tacho to the IG terminal (that's towards the bottom right
hand corner of the connector block. The TEN <- > ground shorting wire is
necessary to properly set both idle and timing.
You may find, as I did, that when you connect the external tacho, the
car's tacho reads zero - don't worry, you haven't broken it, it's just
that most budget analogue meters have fairly low impedance and affect
the tacho filter, so the internal tach doesn't see any pulses.
The idle speed adjuster (close-up view) is at the front of the intake manifold on the
passenger side, and should be covered by rubber plug. When I did my
timing, I hunted around for this plug for a bit before realising that
the plug wasn't there and the speed adjuster screw was exposed. So look
for either a likely looking recessed screw, or a rubber plug that looks
like it's hiding one.
To increase the idle rate, turn the screw anti-clockwise. It looks like
it's about half a turn for about 500 rpm. The manual I had said that the
idle speed should be between 800 and 900 rpm, but I set mine a little
higher to get rid of the idle-droop I was getting from time to time.
When you're all done, bung up the timing adjuster plug, remove the
jumpers, clip the diagnostic connector top, drop the hood and have a
blast :-)
1992 skyline R32
1994 s13 gpsports driftebil
x1992 mazda mx5 turbo
x1991 nissan 200sx
terminals are.
blast :-)
1992 skyline R32
x1991 nissan 200sx
