ratt til xbox
Ola
Tips til ratt til xbox?
Er n00b til xbox, å ser etter et bra ratt med force feedback.
Fant et som heter speedster fanatec 3 eller no, men det koster jo litt å da.. 12-1300kr.. Er det dette som gjelder, eller har man andre alternativer..?
03` Volvo V70 d5 197hk 470nm
01` Seat Leon 4x4 20vT
X: 92` Bmw 328 turbo 600+hk X: 85` Bmw E30 286hk+ M-power X: 86` Audi 90 Quattro 20v Turbo 400hk X: 86` Bmw M535i Turbo 500hk
Vel, Force Feedback får du ikke til xbox.
The first thing one should know about the Speedster is that this is not a true force feedback wheel. But don't blame Fanatec for the omission, because the Xbox system itself currently does not support force feedback. The wheel uses the same rumble channel that shakes your Xbox controller to provide its simulated force feedback response. Although this means the kind of "push" provided by a proper force feedback wheel is not present in the Speedster, the amount and range of feedback provided by the rumble channel is admirable. You can expect to feel a good portion of the bumps you encounter when turning laps at Laguna Seca or Tsukuba, but steering never becomes a chore, even at the highest force effect and steering-resistance settings. Contact with other cars and other track impediments, such as fences, bumpy curb strips, or grass is noted by the wheel's feedback system, as you'll feel a sturdy rumbling that will keep you sweating through the tight, quick corners. We've seen more-responsive feedback systems in other wheels, especially when it comes to minor undulations in asphalt, but for the most part the Speedster does a fine job with what it has to work with.
Kilde
Ok. Da vet jeg det..
Men har noen prøvd dette rattet i den testen? Ser ut til å være av de bedre alternativene det der, men greit å vite hvordan følelsen er under bruk.. Om det rister i hytt å gevær (da er det like greit å droppe hele force greia), eller om det gir den ekstra følelsen av høy fart og nogenlunde realisme..?
  • 3 years later...
