selger subb og monoblokk
kisen
monoblokk : Alpine MRD-M1005 MONO V12
[Amplifier Power Features]
• Amplifier Link (05 type)
• Phase Selector
• Speaker Input (RCA conversion)
• RCA Pre-out
• Independent Variable Crossover
• Bass EQ (45Hz, +15dB)
• Subsonic Filter (OFF / 15Hz / 30Hz)
• Over Current Protection
• High Temperatur Protection
• STAR Circuit
• Digital Control Center Display
• Discrete Pre-amp Stage
• DC-DC PWM Power Supply
• MOS-FET Output & Power Supply Transistor
[Amplifier Power Specifications]
• Weight 5.0 kg
• Dimensions 360 x 60 x 220 mm
• Frequency Response 20Hz-20kHz (0, -1dB)
• Input Sensitivity 0.1-0.8V (at10k ohm)
• S/N Ratio 90dBA
• 500W x 1 RMS (4ohm, 12.0V, 1% THD+N)
• 700W x 1 RMS (2ohm, 12.0V, 1% THD+N)
• 700W x 1 RMS (4ohm, 14.4V, 1% THD+N)
• 1.000W x 1 RMS (2ohm, 14.4V, 1% THD+N)
• Max. 1.800W x 1
KICKER - Solo-Baric 15 L7 4 Ohm DVC
aluminum deposit cone
non-resonant aluminum basket
Santoprene rubber surround
dual 4-ohm voice coils for wiring flexibility
frequency response 20-100 Hz
power range 150-1000 watts RMS
peak power handling 2,000 watts
Sensitivity (dB 1W/1M) 88.5
Frequency Response (HZ) 18-100
Mounting Depth (IN., CM) 8-3/16, 20.8
Mounting Cutout, Square (IN., CM) 14-1/16, 35.7
Min Rec Sealed Box Vol (CU. FT., LITERS) 1.5, 42.5
Max Rec Sealed Box Vol (CU. FT., LITERS) 6.0, 169.9
Min Rec Vented Box Vol* (CU. FT., LITERS) 3.0, 85.0
Max Rec Vented Box Vol* (CU. FT., LITERS) 6.0, 169.9
kom med bud...
