Pioneer avh-p7500dvd selges
Nuttza
Hei selger min lite brukte multimedia spiller, dette er en p5700 dvd som er fra statene.
Kjempe flott spiller , lite bruktog utrolig mange fineeser.
NB: dette er en spiller fra usa
Key features AVH-P5700DVD
All-in-one design, no hide-away unit
6.5-inch Anti-Glare, wide-screen display
Fully motorised Touch Panel Display
DVD-Video, DVD-R/DVD-RW compatible
CD/CD-R/CD-RW/MP3/WMA CD playback
MOSFET 50 W x 4 Amplifier
D4Q Digital AM/FM tuner
iPod® adapter ready
General AVH-P5700DVD
Amplifier MOSFET 50W x 4
Equaliser EEQ+ Equaliser med HPF, LPF & SFEQ
CD Player Nei
Built-in AM/FM RDS Tuner D4Q
DVD Capabilities DVD-Video/Video CD Playback with Direct Search, Chapter/Track, Next/Previous, Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title, Time Direct Search, Scan, Digital Direct
DVD Auto Play (Some discs may not fully operate on this system), DVD Bookmark Play, DVD eject Bookmark Play
CD Capabilities CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search
96KHz/24-bit DAC
24-bit D/A converter
Track Search/Scan/Repeat
Track/Manual search
Last position memory (for CD function only)
Source Control MCD, TV DVD, DAB Tuner
Control via frontpanelknappene eller fjernkontroll
Voice Guidance Når den er koblet til Pioneer Navigasjonssystem
Display type Wide TFT active matrix LCD colour display
Touch Panel Operation Ja
Display size 6,5 Inch
Screen Coating High-quality AG (Anti-Glare)
Installation possibilities In-Dash
One-touch detachable display Nei
Fully motorised display with auto dimmer with free adjustable viewing angle (50°-110°)
Front panel Partially removable with safety warning beep
Selectable wide screen modes Just / Full / Cinema / Zoom / Normal
Auto display brightness & backlight adjustment Nei
Built-in speaker with volume control Nei
Rear camera switching Ja
Remote Control Tilleggsutstyr
Dome light Nei
D/A Convertor 24-bit
DVD - R/RW and CD - R/RW Playback Ja
Built-in MPEG 2/1 decoder Ja
DVD video player Ja
Region number 2
Connections AVH-P5700DVD
AV Output 1 RCA
AV inputs 2 RCA
AV Bus Input Ja
Input for rear camera Ja
RGB input for Navigation System Ja
Optical Digital Output Ja
IP Bus input/output Ja
PAL/NTSC/SECAM compatible RGB input Ja
Power Supply In Ja
Rear monitor output
Spillern selges for høyeste bud over 4000. pluss frakt
Hei.
jeg har desverre ikke noe å ta bilde med, untatt mobilen, jeg kan godt sende det på mms .
spillern er ikke mere enn 6 mnd gammel, så den ser ut som ny,ser ikke brukt ut i det hele tatt, jeg kjøpte den for ca 2 mnd siden , men nå skal jeg ha ny bil å der er det itegrert spiller så får dessverre ikke brukt den.
Er det AVH-P7500 du skal selge eller er det AVH-P5700? Er en vesentlig forskjell så du bør endre til det som er rett... står nemlit forskjellig i tittelen din og i annonsebeskrivelsen din :)
*1999 Audi TT ~The Bi-TT-ch~
Hvor gammel er den spilleren din? Og hvorfor selger du? Ser jeg kan få bestilt meg samme spilleren til $699 (4500,-NOK ink. frakt) Fra statene selv så...
Men jeg kan starte med et bud på 3 000,- hvertfall, forbeholdt at den er strøken og feilfri :)
pluss frakt pluss moms, pluss sjangsen for at du aldri får den.
4500,- ink frakt. Klart du får spilleren, har bestilt varer fra statene i snart 4 år hah... Men men, i forhold til norsk pris blir det billig uansett :)
