Nye 911 Turbo og GT3 (997)
marcos_eirik
Nye 997 Turbo vil bli vist på Geneva Motor Show i slutten av inneværende måned...
Porsche is extending its current product range with the addition of a new 911 Turbo. The sixth generation of the 911 series’ top-of-the-range model will be celebrating its world premiere on February 28, 2006 at the Geneva Motor Show and will be available in German dealerships as from June 24, 2006.
The 911 Turbo (Type 997) now has an output of 353 kW (480 bhp) at 6,000 revolutions per minute, 60 bhp more than its predecessor (Type 996). The specific output of the 3.6-litre boxer engine thus climbs to a new all-time high of 98 kW (133 bhp) per liter of displacement. Rated torque has been increased from 560 to 620 Newtonmeters. The speed range in which this power is available has also been extended. While the previous model’s maximum torque was available between 2,700 and 4,600 revolutions per minute, the corresponding figures are now 1,950 to 5,000 revs.
These improvements are translated into driving performance. The new 911 Turbo with six-speed manual transmission requires 3.9 seconds for the standard sprint from zero to 100 km/h. The coupé reaches the 200 km/h mark in 12.8 seconds. And just 3.8 seconds are all it takes for the most powerful series-built 911 model of all time to accelerate from 80 to 120 km/h in fifth gear. Despite these enhanced performance statistics, Porsche developers succeeded in reducing average fuel consumption by one tenth to 12.8 liters per 100 kilometers.
The 911 Turbo with the optionally available Tiptronic S automatic transmission puts in an even more impressive performance. An optimized setup gives the vehicle the wherewithal to power from zero to one hundred in just 3.7 seconds and to reach 200 km/h after a mere 12.2 seconds.
The Turbo with automatic transmission also has the advantage when it comes to flexibility. In penultimate gear it accelerates from 80 auf 120 km/h in 3.5 seconds. Fuel consumption by the Tiptronic S variant is 0.3 liters lower than that of its predecessor: 13.6 liters in accordance with the EU standard. Both transmission variants have a top speed of 310 km/h.
The vehicle’s flexibility can be enhanced even further with the optional “Sport Chrono Package Turbo”, available for the first time. Here the driver selects the “sports button” adjacent to the gear lever to activate a short-time “overboost” at full throttle. This increases boost pressure in the mid speed range by 0.2 bar for up to ten seconds; torque rises by 60 to 680 Newtonmeters. The time required by the 911 Turbo with manual transmission for intermediate acceleration from 80 to 120 km/h is reduced by 0.3 seconds to 3.5 seconds.
These performance figures owe themselves to exhaust turbochargers with variable turbine geometry, featuring for the first time in a gasoline engine model. At the heart of this technology are adjustable guide blades, which direct the engine exhaust flow variably and precisely onto the turbine wheel of the exhaust turbocharger. The principle of variable turbine geometry unites the advantages of small and large exhaust turbochargers and leads to a discernable improvement in flexibility and acceleration, particularly at low speeds.
To transfer the available power to the road, the new generation of the 911 Turbo features a redesigned all-wheel drive with an electronically controlled multi-disc clutch. Porsche Traction Management (PTM) ensures variable power distribution to the two driven axles. Depending on the driving conditions, the all-wheel electronics system constantly determine the optimal torque distribution to ensure the best-possible drive. In practice this translates as high agility on narrow country roads, outstanding traction in rain and snow and optimal active safety even at high speeds. These properties make the Porsche Traction Management system in the new 911 Turbo one of the most powerful and, at the same time, lightest all-wheel systems on the market.
The new 911 Turbo’s driving performance is duly tempered by its brake system, which comprises monobloc fixed-caliper disc brakes with six pistons at the front axle and four at the rear.
In comparison with the Type 996, the diameter of the internally ventilated and perforated brake discs at the front and rear wheels has been increased by 20 millimeters to 350 millimeters. As an option, Porsche is also offering its optimized ceramic brake system, PCCB (Porsche Ceramic Composite Brake). The advantages of this high-tech material mean a reduction of 17 kilograms compared to the standard brake system, excellent fading stability owing to consistent friction values and absolute corrosion resistance. The brakes now have a diameter of 380 millimeters at the front axle and 350 millimeters at the rear.
A characteristic design feature of the new 911 Turbo is the modified front end with its distinctive, tautly drawn cooling air inlets. In conjunction with the standard-equipment oval bi-xenon headlights, they define its unmistakable image. The harmonious front view is enhanced by widely placed and deep-set fog lights and by new LED flashers, which are situated in the lateral air inlets of the front end. From the rear perspective too, the Turbo takes on a more powerful appearance. This is due first and foremost to its tail end, 22 millimeters wider than that of the previous model, to which the redesigned wing spoiler element has been aligned. It now slopes downward slightly at the sides to nestle into the contours of the rear fenders. The lateral air inlets behind the doors have also been redrawn and, together with the new air ducts, afford a more efficient supply of cooling air to the charge-air intercoolers.
The basic Euro price for the 911 Turbo is 115,000 Euros. In Germany it is available for 133,603 Euros including value added tax and country-specific requirements. In the USA the 911 Turbo is priced at 122,900 Dollars (not including taxes), and will be available as from July 8, 2006.
In addition to the 911 Turbo, as a special surprise at the Geneva Motor Show, Porsche will be presenting another world premiere: the new 911 GT3. You will receive technical data and photos of this “racing car for the road” on February 28, 2006, the first press day in Geneva.
Store bilder her...
Porsches egene side til bilen (Masterwerk) finner dere her
Like interessant som nye 997 Turbo er vel 997 GT3 som vil bli vist på Geneva Motor Show sammen med den. Infoen nedenfor er sakset fra Porsches internettside...
The story of Porsche is one of remarkable success based on two fundamental principles: technical innovation and the application of each new development to the genuine needs of the driver. With the new 911 GT3, we have applied these principles to unique and compelling effect. Drawing on pure racing origins, we have created a road-going car that is equally well suited to everyday driving and genuine competition use.
Noen fotografier fra en brosjyre har tydeligvis kommet ut...
Hele settet med bilder finner dere her...
identitet er viktig når det gjelder 911..
996 kom litt bort i fra den opprinelige 911 "looken" , med 997 har de tatt et steg i riktig retning og designet en bil som ligner mer på 993.
Når en ser en 911 skal en ikke være i tvil om hviken bil det er..
Do you understand the words comin outa my mouth?
Vil ha en 911 Turbo S (520 hk) jeg !!! Kommer sikkert o vare med på bilsalongen i stockholm 1-9 / 4... GT3 blir rå den med, 400 hk i en bil som veier 1360 kg.
Porsche er best !!!!!!! Beste Porsche: Carrera GT !!!!
Gran Turismo 4 Game Status: 100 % !!, 279 biler, ca 3,190,000 Cr. ca 36,600 A-spec pts.
http://www.mustiracing.tk, http://www.freewebs.com/mustiracing
hmm, min bil veier bare 1275kg .. :)
Men så er dette sugehester da.. 415 for å være helt nøyaktig og 405nm med turtallsperr på 8400rpm skulle det bli tøft på en flat 3,6liter bokser sekser. selv om den blir 1395 kg , ikke 1360 (pirke pirke)
Da er det GT3 RS som blir 1360 kg... Har hørt at en RS ska komme senere.
  • 1 month later...
Nå er den her...
With effect from October, Dr. Ing. h.c. F. Porsche AG of Stuttgart, Germany, will be launching the new 911 GT3 RS on the European market. This purist variant of the GT3 is particularly suited for use on the track. The GT3 RS is distinguished by its performance capability and the unadulterated driving experience enjoyed with a racing car, but also meets all requirements for road-legal sports cars.
The exceptionally meaty engine boasts a displacement of 3.6 liters to generate 305 kW (415 bhp) at 7,600 rpm. Maximum revs are reached at 8,400 rpm. The power output per liter of engine capacity is 115.3 bhp. These figures correspond to the present GT3. But the RS puts in an even better performance. Thanks to a close-ratio six-speed transmission with a single-mass flywheel and the 20 kg lower vehicle weight, the engine revs up even more freely, thus enabling the 911 GT3 to sprint from zero to 100 km per hour in 4.2 seconds. That's one tenth of a second faster than the GT3. It takes just 13.3 seconds to hit to 200 km per hour. Maximum speed is 310 km per hour.
The reference "RS" will quicken the pulse of Porsche connoisseurs. Models such as the legendary Carrera RS 2.7 of 1972 and the type 964 911 RS (1991) were also sports cars that stood out on account of an extreme degree of maneuverability and handling. That tradition is continued with the new 911 GT3 RS. In common with its predecessors, it provides a basic and pre-approval model for use in a range of racing series.
One characteristic of the new "RS" is the body, which is 44 mm wider at the rear (a legacy from the Carrera 4 models) by comparison with the 911 GT3. The muscular-looking rear end conceals a wider track that not only improves directional stability but also increases the transverse acceleration potential of this two-seater coupe.
Despite its specialized body, the "RS" is 20 kg lighter than the GT3, weighing in at just 1375 kg. This weight-saving was achieved by the use, amongst other solutions, of an adjustable carbon fiber wing, the use of a plastic rear lid and a lightweight plastic rear window. The corresponding weight-saving is 4.5 kg/kW.
With a view to the registration regulations for the important Gran Tourismo championships as future fields of application, the road version of the GT3 RS has resorted to technical solutions that will also feature in the racing version. These solutions will include the entire wheel carrier and split wishbones on the rear axle, in addition to the carbon fiber components of the body.
And the interior lives up to the vehicle's sporting aspirations: 2 lightweight bucket seats made of carbon fiber composite materials come as standard and in the club sports package. There is a bolted roll cage and the pre-wiring for the battery main switch. A six-point seatbelt for the driver and a fire extinguisher are also provided. Internal trims are black, with the roof lining, steering wheel and gear stick trimmed in high-quality Alcantara leather.
The available finishes are Arctic Silver metallic or black; as an option, the GT3 can also be obtained in orange or green. All vehicle insignia and the wheels themselves are styled in orange or black to contrast with the body paintwork.
The basic price for the 911 GT3 RS is €111,600 (excluding country-specific requirements). In Germany, the coupe costs €129,659 including sales tax. The GT3 RS will also be available for sale on the North American market from March 2007.
Store bilder her...
Porsches egen side finner dere her...
  • 4 weeks later...
