Lanzar OPTI2000D 3000,-
grandre
Selger en Lanzar OPTI2000D til 3000,-
Kjøpt ny for 1,5 år sia for 7 lapper, sitti i bil hele tiden.
700 Watts RMS Power into 4 Ohms
* 1100 Watts RMS Power into 2 Ohms
* 1600 Watts RMS Power into 1.3 Ohms
* 2000 Watts Max Power into 1.3 Ohms
* 4000 Watts Bridged Max Power into 2 Ohms
* Mono Block Subwoofer Amplifier
* 1 Ohm Stable
* MOSFET Power Supply
* PWM (Pulse-Width-Modulated) System
* Double Sided Epoxy PCB Circuit Board
* Nickel Plated RCA Inputs
* Custom Terminal Block for Speaker Connections
* Thermal, Overload and Short Protection
* Variable Subsonic Filter: 15Hz~40Hz, 24dB/Octave
* Phase Shift Control: 0 to 180 Degree
* Remote Bass Control
* Input Impedance: 10k Ohms
* Soft Turn On/Off
* Heavy Duty Power Coated Heatsink
* Class-D Design
* Low Pass Filter: 50Hz~150Hz, 24dB/Octave
* THD @ 1Watt/4 Ohm: 0.1%
* S/N Ratio: 90dB
* Frequency Response: 15Hz - 150Hz (+/-3dB)
* Damping Factor @ 20Hz/4 Ohms: 400
* Bass Boost: +18dB
* Dimensions: 10.08"W x 2.12"D x 19.1"L
* Line Output Impedance: 100 Ohm
* Fuse Rating: 30A x 6
- 92 Audi S4 2.2 Turbo
x 98 Audi a4 Avant 1.8 TQBilstereo prosjektSolgt
x 90 Audi 90 coupe 2.3 Solgt
x 91 Lada samara 1.3 Solgt
